Found solution round Oculus medium "Fatal error - medium crashed"
Muni2
this is what worked for me: I am in!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I can open Medium. No more fatal error /medium crashed.
For me, the solution was to update the drivers of my NVDIA Geforce 1070. BUT on NVDIA website it does not work. When I installed the suggested driver it said not compatible with hardware. Only when I downloaded the NVDIA suite on my laptop and did the search manually and ran all the tests, i was able to install the right driver (including updating Java)). I then needed to totally uninstall Oculus, re-install Oculus and then re-install medium. Sooo happy that it is working now. Muni
malekula999
this is killing me ( reinstall all stuff to run back medium (
jessicazeta
Level 7
@malekula999, responded to you here - https://forums.oculusvr.com/community/discussion/68786/medium-crashed#latest
@Muni2 - WOOOOOOOOOOOOOO!!!!
