Problem : Medium folder missing, cannot create stamps
sinusmagnus
Honored Guest
Hello, I am reporting an error with medium :smile:
The medium folder is missing IN APP and i cannot create stamps because I have a path error.
On windows, the folder is there and all the files are there including sculpts, stamps, etc.
But when i am inside medium it seems it cannot find the folder. I can save/load sculpts in the personnal library, but when i want to go to the windows folder i just cannot see it inside medium.
EDIT : I tried to change the folder to Desktop with regedit
(tip found in this post https://forums.oculusvr.com/community/discussion/57570/oculus-medium-keeps-creating-a-onedrive-docum...)
==> Same problem in desktop : medium cannot see its own folder it's working on ?
Any solution for this ?
Thanks for the support
Screens attached
0 REPLIES 0
