medium crashes every time I try to create create a stamp. HELP!
shake128
Im running a vega 64 on the latest drivers.
Since the last update (i believe 2.3) came online I can't use the create stamp tool anymore.
When I do, no matter how complex the mesh is, Both my headset and Monitor go black, the computer is forced to restart video drivers, and when the image comes back on the monitor, medium suddenly crashes.
Working with no stamps is terrible, so i really hope this gets fixed soon!
If anyone knows of a workaround it would be greatly appreciated.
11 REPLIES 11
shake128
Additional Information: Creating the stamp from the support hand contextual menu, or importing a mesh as a stamp both produce the same exact fatal crash.
shake128
sorry, while i was trying to post the logs and this message got repeatedly posted by mistake.
shake128
shake128
shake128
shake128
shake128
shake128
rolling back amd drivers from 19.5.1 to 19.4.1 solved it.
jessicazeta
Level 7
Hey hey @shake128, based on the timestamps of your message, I don't think you were on 2.3 - I believe you were on 2.2.5. In any case, possible you could update to the latest AMD drivers, crash, and send us the logs so we can take a look at the issue? We always recommend being on the latest drivers.
