10-24-2021 02:22 PM
I started using oculus link and got blade and sorcery, I opened the new update and the right lens seemed to be black except for the guardian. Once I loaded into the game all I could do was open the book and move the right controller. Anyone else having this problem or have a fix?
10-24-2021 05:41 PM
Hey SavyFN,
We see you're experiencing some Link problems while playing Blade and Sorcery. If we can, we'd like to help out and see if we can narrow down the issue.
To do that, we'd like you to answer some questions:
We're going to do out best to help you out. Feel free to reply to this post so we can get you back gaming.
10-24-2021 06:24 PM
It only happens when using blade and sorcery, just started in the new update. I will try uninstalling it. Thanks!
10-24-2021 06:33 PM
Of course SavyFN!
Please let us know if that fixed the issue or if the problem still remains.
10-24-2021 07:04 PM
I uninstalled and reinstalled, problem still happening.
10-24-2021 07:43 PM
Thanks for that, SavyFN
We did do some research and wanted to ask if are you using any mods? It appears some members of the game's community are reporting that you need to delete all of your mods to successfully play the new U10 update.
Should you not have any mods, or have already tried uninstalling your mods, it may be worth your time to continue researching this issue and filing a support ticket with the Blade & Sorcery developer.
