09-07-2022 09:54 AM
I bought blade and sorcery nomad on the quest, and it says that it is purchased, but for some reason, when I go into my library, it doesn't show up. I've tried rebooting, factory resetting, and rebooting, but nothing seems to work. Can someone help me out with this problem
09-07-2022 12:29 PM
Try going into the store and download the game. It does not show up in your library unless you have it installed
09-07-2022 12:41 PM
I did that, but now it is stuck on a loading purchase (going around in a circle)
09-07-2022 12:49 PM
Try waiting a bit, or reinstalling it.
09-07-2022 02:29 PM
its been going on for a day now and it won't even install
09-07-2022 06:56 PM
@RuinedPieces101 Yeesh, sounds like quite the issue there.
Your next best bet would be to probably request a refund to see if you can re-buy then play the game?
In order to request a refund automatically, you may want these steps:
If that doesn't seem to work, you might want to hit up the support team for either Oculus or Blade and Sorcery: Nomad.
