Colors are washed out, how to adjust?
Alaaeldin945
Hello, my oculus quest 2 has washed out colors (so low saturation), compared to my TV and PC, how to adjust it and increase contrast and Saturation.
Thanks
iMight404
Oculus Support
Oculus Support
Sounds like you may have night mode enabled. I would check that Night mode is off in quick settings. You could also try color correction in accessibility. Can you shoot over a video so we can get an idea of the issue?
Take your destiny into your own hands. Sand cannot keep a shape by itself, but add water and it becomes malleable. Fate can be such, if you add the right element.
