Everytime i connect my USB cable to my quest for link and I aciddently make the wire move a little
Generalconquer5
bit, it crashes
san10der
Sounds like your cable may be degrading or have a weak connector? Maybe try getting a right angle USB connector and run the wire down the back of your headset with some velcro straps. Give the cable a little slack though as you don't wanna be pulling on the USB C port of the Oculus Quest.
