GTX 1650 max q
ulrikrl
Hi! Wondering if my laptop would work with oculus quest 2, even though i know the gpu is not offically supported. Anyone has any experience with Oculus Link or virual desktop?
Laptop specs:
CPU: Intel Core i7 (8. generation) 8565U / 1.8 GHz (turbo 4,6 GHz)
RAM: 12 GB
Graphics: NVIDIA GeForce GTX 1650 with MAX-Q / Intel UHD Graphics 620
altriawave
I have the same issue.  You can solve this problem by using virtual desktop.  I can use it to play half-life:alyx. But the quality of playing game is not very good.
