How do you click, select swipe etc on Quest 2 without a controller?
taidoq2vr
I wonder if anyone uses Quest to watch movies in a confine space such as airplane seat without a controller?  If so, how do you click, scroll, select etc.
Advance thanks for your feedback!
4 REPLIES 4
PITTCANNA
Level 12
you can use gaze pointer but it gets to be a pain the butt.
Meaning turn on your quest and don't touch your controllers to wake them up.  A point will appear then you can use the + volume button to select.
lensmandave
Level 9
You could use hand tracking maybe?
Intel Core i7 6700K @ 4.5GHz. Asus-Z170-PRO MB - CORSAIR H105 HYDRO CPU COOLER EVGA GTX 1080Ti FTW3 Elite - 16GB DDR4 2666MHZ HYPERX SAVAGE.
taidoq2vr
Thank you all for your feedback!  Will give gaze and hand tracking a try.
taidoq2vr
Try both, gaze and hand tracking doesn't seems to work with Skybox as I receive notification that it need the controller.
