I Can Only See On Monitor And Not Quest Using Oculus Link
Starman1849
Hello! I am having trouble with my quest when using oculus link. Whenever I plug in my quest I go through the set up and everything works until I start playing a game (Roblox VR). Whenever I go into the game I can see in my monitor what i should be seeing in my quest, but whenever I put on the headset it is just a black screen. My guardian still works, but I can not go to the home screen, and I can not see anything other than my guardian. Whenever I move my controllers and head it works in the Roblox VR game, but I can only see it on my monitor. I am using a ten dollar USB 3.1 to USB c cable from amazon for my oculus link cable. My thought is to get a new cable but I wanted to see if there is anything else I can do before I purchase a new cable. Any suggestions?
14 REPLIES 14
enigma01
Level 10
I take it you have followed the instructions to enable Unknown Sources within the Oculus desktop app etc?
Do any other games or experiences work with your existing cable? If they do, then I doubt it's the cable causing the problem.
Starman1849
I have turned on Unknown Sources and i cant try any other game, because i dont know of any other free game.
dburne
Level 16
Try it with the charging cable that came with the Quest and see if you get an image in headset of at least Oculus Home with Link.
Rift CV1| Rift S| Quest| Reverb G2| Index
Starman1849
Whenever I use the cable that came with the quest it doesn't work, and it says that you cant use the original cable that came with the quest.
dburne
Level 16
Oculus changed that in latest version of software.
But if you already tried and it did not work for you that is another thing.
Starman1849
yea, I already tried it and it didn't work. Sorry to respond so late.
Starman1849
I saw on another forum that I had to go to settings and restart my oculus software, along with restarting my headset, and disconnecting the cable, but that didn't do anything. I'm still having trouble with it.
ufcfan
Does the Oculus PC app recognize your Quest. In the device menu does it say connected. If so, then you may be right. All cables are not created equal. I have had many issues over the years that were a result of less capable or actually faulty cables
Old Guy that's involved in anything Tech, Computer, Hi Fi Audio, HTPC and now VR
Starman1849
yes, it does say its connected, and recognized.
