Showing results forย
Search instead forย
Did you mean:ย
Microphone not Working on Quest 2.
Jferrer0
The microphone used to work like it normally should but now it doesn't it says that the microphone is connected even when I have it disconnected or otherwise turned off.
I really have no clue what to do and I was wondering if there was anyone who might know what is going on and how to fix it, I tried turing it off, setting it up as my default device, but that hasn't worked, it is permanently stuck like that, it acts as if it was active but it is not.
Strongit
Level 7
Mine looks exactly the same with the green bar but it works just fine.  Which games have you tried it with?  It may just be one app that doesn't work.
Oculus Quest 1, Anker Powerline cable with CableCreation active 16.5 ft extension
i5-8600K @ 4.7 GHz, eVGA 1080 ti FTW3, Gigabyte Z370 AORUS Ultra Gaming, 16 GB 3200 MHz RAM
