Microphone not working
KiritoSan_
I need help my microphone has some kind of problem
it doesn't work in games like
VRChat and RecRoom
1 ACCEPTED SOLUTION
Accepted Solutions
MetalGearHazumu
Same. Mine wasn't working either
52 REPLIES 52
MetalGearHazumu
matt_redman_779
Or mine ! Any idea how to fix the problem ?
MetalGearHazumu
What has no eyes and no legs? Still no idea
KlodsBrik
Level 11
Isn't the mic disabled by default in VRchat ?
 If I remember correctly there is an option to turn it on in vrchat settings.
 Offcourse it might be different with Quest. Any options in quest  setting to rurn it on ?
I Cant load up vrchat right now on my rift to check out where the setting is, but try looking for it ?
Be good, die great !
MetalGearHazumu
Yeah, there is a mute button but and a mic level option in settings but none did anything. The mic on the UI with the menu closed was red though. Don't know what that means
ShowbizDonkey
Oculus Community Manager
If you haven't already, can you please contact customer support so they can look into this for you? Thanks!
MetalGearHazumu
I have :smile:
iN5OMANiAC
Reboot the headset and it works. It doesnt work on this or Bigscreen straight out of the box for some reason, needs you to restart the Quest
MetalGearHazumu
Interesting and weird. I'll try it out tomorrow
