Mirroring is not working more than few minutes
olivier_oculus
Hello Oculus Team
When I link my Quest to my iPhone X (on the main menu), it works only 2 - 3 minutes and then it's impossible to link (quest and iPhone are on the same wifi)
I have this message in french "Impossible to launch mirroring, someting about the wifi blablabla. Cancel or Try again)
Any idea why ?
3 REPLIES 3
SteveG7RTA
Level 7
Are they definitely on the same WiFi band? If your router has both 2.4ghz and 5ghz.. and if the SSID is the same for both, then there’s a chance the Quest or your phone keeps switching bands (I once had this problem)
If this is the case, then go into your router settings & rename one (of both) so that both bands are showing. You can then connect to whichever you prefer....  if your router will let you do this of course. I know others on this forum have said their router won’t let them.
olivier_oculus
YOU-ARE-THE-BEST
It work perfectly now
Thanks a lot from Paris
SteveG7RTA
Level 7
Great, glad it worked ??
