Movement directional settings NEED HELP
Afflicted66
When I set up my quest 2 it asked me what settings I wanted to use in regards to when I pushed forwards on the directional stick, do I want to go in the direction that I was looking or the direction that I am pointing the controller. I selected the pointing option which I now realise was a terrible idea and want to change it back but I cant find the setting to do so anywhere! Do I need to factory reset the headset to do so? It makes some games unbearable to play especially shooters where you need both hands on the weapon.
SuperBoring2000
Where did you set this up? I never saw the question you mention. Is that inside a specific game?
Afflicted66
I swear when I first used the headset/initial set up it asked me the question. I've checked settings inside game settings and cant find it anywhere for multiple games.
