Oculus Link Audio Cutting out
Nadav2005
I have been using Oculus Link for almost two months and I very like it, until two weeks ago there were no problems at all.
Two weeks ago when I came to play Beat Saber. I noticed that the sound that comes out of the headset includes the sound if the headphones are connected to the headset sounds interrupted (sound is cutting down every several seconds).
I did not think that the problem was terrible so I did a restart to the computer and the headset, and noticed that nothing has changed. I then deleted the Oculus software on my computer.
And once again did not help, I did a factory reset for the headset and also did not help, I tried 2 usb 3 cables that I know for sure are working.
I tried two different computers that support virtual reality. I searched a lot of solutions on youtube but nothing helped.
But when I didn't use link the sound is excellent with no issues. Even when I use virtual desktop.
my routher is pretty bad, and I really liked the link. I'd love for someone to help me.
7 REPLIES 7
bosssschetar
i have the same issue. I am using the oficial cable link but the same issue. Even with external headphones i receive the same cutting sound
Nadav2005
Did you find a solution?
B1uto
Reporting same issue.  Been rock solid with quest link on quest 1 for 4 months.  Quest native is fine.  When jumping into PCVR, menu audio is low, and choppy.  In multiplayer people's voices are extremely low.  Media playback audio is choppy. Quest version 23, Oculus version 25.
Thank you
bosssschetar
Guys for me I found the solution. I changed the Bitrate from 500 mbps to 250 mbps. After this step, the sound was good
Nadav2005
i love you mannnnnnnnn
How do you change the bitrate?
I changed the bitrate from the default to 250 mbps @ Program Files\Oculus\Support\oculus-diagnostics\OculusDebugTool.exe.  It did not resolve the Oculus Link audio stutter.
