02-02-2020 03:20 PM
02-07-2020 03:10 PM
02-07-2020 04:03 PM
02-07-2020 06:39 PM
briochebro said:
FreiherrSeymore said:
how do i even disable autoupdates?
This is exactly what i expected to happen as facebook stepped in
On your phone, in the Oculus app, go into Settings, click on your device, then "More Settings", then "Advanced settings". Then turn off "Update Software Automatically".
In the Windows app, go to Settings > General, and turn off "Automatic App Updates".
02-08-2020 04:13 AM
Yeah, even if you turn off "Automatic App Updates" the actual Oculus App will still update automatically. It just won't update the apps that you have in your library.
When I run the repair tool it updates me to version 13. Within minutes it starts to automatically roll me back to version 12. Clicking the pause or X next to the download does nothing. Turning on PTC, it updates me to version 14, turning off PTC rolls me back to 12.
Even though the "What's New" under the "Oculus Software Update" gives release notes for version 13, it still rolls back to version 12.
02-08-2020 04:17 AM
02-08-2020 04:28 AM
02-08-2020 04:31 AM
garfinnabag said:
Yes i did it i repaired the oculus app then i turned off the internett and pc then i started my pc and it worked, btw do not turn on internett and close the app before you do
02-08-2020 06:49 PM
02-09-2020 05:03 AM
andrea.tarricone said:
- So you turn off the internet connection when the oculus app is opened?
- After the repair you got the v13?
02-09-2020 05:10 AM
