Oculus Link not connecting
davinasdaddy
Just bought a new USB 3 type C to type C cable that specifically mentions support for Oculus Link but I'm not having any luck.
On the "connect you headset" screen I was previously (with USB 2 cables) at least getting it recognised that my quest 2 was connected but the connection was too slow.
Now it just keeps spinning around waiting for the connection. In the headset I had a prompt for allowing storage access which I accepted, and it is charging, but no prompt or option for starting link (is there supposed to be one?) and the PC side just kept spinning.
Any ideas?
0 REPLIES 0
