Oculus Link work with sensors
fab193
So I was having some issues with tracking while using oculus link to play some games on my pc. So I was wondering if I could use the sensors for the rift along with the tracking to get a better more precise tracking for while I use the oculus link function with my Quest 2
PITTCANNA
Level 12
i don't think it works like that.  The quest 2 controllers are not recoginized by the rift sensors.  if you look at how the ring is its on the underneath instead of being on top.
