Showing results forย
Search instead forย
Did you mean:ย
Oculus MRC tool - Audio mixer OBS
Xeyh
Hi guys,
I follow the official guide about the Oculus Quest Mixed Reality Capture and it's working for me. (+Some YT video!)
Green screen / background: OK
Latence: OK
Audio: Not KO but no OK too
When I record, there is no problem at all with the calibration but I'm in trouble with the OBS audio mixer setting for the Quest 2.
By default, there are no audio when I record.
So I turn ON "Oculus MRC" and there are audio in my records.
But the sound is really bad...
If I turn OFF the "Desktop Audio" + ON "Oculus MRC" there is not sound at all.
If I turn ON the "Desktop Audio" + ON "Oculus MRC" + put -15 -20 DB on "Oculus MRC"... it's better but not enough...
PS: For all my setting, I turn OFF the microphone source "Mic/Aux".
Some one record video with Oculus MRC + OBS ?
And have the same issue ? Or fix it ?
Any idea of the audio mixer setting ?
Thanks for your help
PS2: Sorry for my English, I eat bread and cheese... French ? Yes I am !
Xeyh
To update this topic, I fix the issue:
My issue was a hardware issue...
The audio was on my "loud speakers" and with an USB headset / headphone it's working very well !
Microphone was disable in all cases but don't know why with the loud speaker ... the quality drop.
