10-17-2020 12:29 PM
Hello everybody.
I am experiencing issues with my new Oculus Quest 2. The controller tracking does not work.
I will try to explain the problem as best as possible. The rotation for the Oculus Touch controllers works perfectly, but the position of the controllers does not work at all. I will move the controllers around but they still appear to be in their initial position, and it will only update after a while, and then be stuck again.
I tried hand tracking, and it works very well, but the controllers don’t.
I have already tried a lot of things to fix the issue. I unpaired and re-paired the controllers through the app. I have restarted the headset several times. I have done a factory reset on the headset through the app. I have replaced the batteries on the controllers. I have charged my headset almost fully, since it came with low battery. I tested the cameras and they appear to be working well. I cleaned the cameras with microfiber cloth. All this to no avail and the issue still persists.
What could be the problem?
Is there anything I can do?
Best Regards, Viktor.
10-19-2020 03:23 AM
12-06-2020 10:15 PM
12-11-2020 02:51 AM
12-11-2020 06:54 PM
ivapemandalay said:
My problem is worst . The tracking is totally stop working even after the factory reset. RMA from my country will cost more than buying a new one . So i just keep looking for the solution everyday here 😞
12-11-2020 08:16 PM
12-24-2020 05:43 PM
01-08-2021 05:58 AM
02-27-2021 09:58 AM
this is probably a dumb question, but ill ask anyways. Have you tried changing the batteries? if the batteries are dead the controllers won't respond regardless of what you do.
03-26-2021 05:55 PM
Same here. Mine is only 2 mnths old. As soon as the original batteries died...I bought 1.5v rechargeable (2 diff sets) and both work well for about an hour into beat saber, then tracking starts lagging...but it still says 100 %. I change the batteries & same thing.. only lasts about an hour .
