Oculus Quest 2 , Enable Link Popup - Air Link Not Working ( Solved Even On Windows 11 )
EgSavas
Hi everybody ,
at first i had connected to my oculus app on pc with AIR LINK and then with Cable Link , it was working since my device removed and then i could not see any ENABLE LINK POP-UP or connect with AIR LINK ,
it seems oculus home app ( on pc ) wont to connect my quest 2 , completely ignored my quest 2 device ,
i did everything ( removing home application and reinstall , Restarted Quest 2 many times and .... ) but didnt work ,
i had chat with Support and they told me use windows 10 , we dont support windows 11 ,
HOW TO FIX :
Just RESET FACTORY ( Quest 2 device ) , and then everything be ok !
( important : all of your apps will be delete and memory will format )
i Lost 80Gig apps and games and i have to Re-Install them again but its ok , my Problem Solved ,
i just wanna to Help to other if you had my problem !
Good Luck
EgSavas
For Reset To Factory : Hold Power Button + Volume(+) for 10-15 sec
