Oculus Quest 2 casting and pairing issues
rachoban
Honored Guest
I'm trying to cast to a Iphone 11 from my Oculus quest 2. I'm running software version 30.?? on the quest 2 and software version 14.6 on my Iphone. I also have the Oculus app on my Iphone.
Question 1: Do you have to have bluetooth running between your Iphone and be paired to you Oculus  for casting to work??
Question 2: Where do you look to see if you are bluetooth paired between you Oculus and your Iphone. How do you check to see if pairing is working.
0 REPLIES 0
