Oculus Quest Dark mode
jacpoon
I have heard that there will be a OS update with a dark mode for oculus quest. Is it only a rumour or is there any scheduled for the update?
Thanks a lot!
8 REPLIES 8
dus10lee
I’d like to Know this as well
enigma01
Level 10
This post here, makes out that it should have been enabled in the last update.
https://www.oqplay.com/news/the-best-oculus-quest-firmware-update-has-arrived/
But I have the latest update installed and when I power on in the dark, I just see a message saying tracking lost move to an area with more lighting.
Emilian1978
I would be VERY happy to be able to reduce the contrast/brightness . For me, as a glasses wearer, many apps are just too bright. I'm also using a dark theme for anything possible...
Spuzzum
Level 9
To my understanding, there's a setting that needs to be enabled before the dark mode shows up. Similar to the public testing channel for the Rift software. ... I think. 😛
dus10lee
Apparently the option was removed in new firmware and will be added back sometime down the road.....:(
Anonymous
Not applicable
Can’t wait for this feature to be released. Watching movies with the need to keep the lights on is just plain .....
JohanTEAswe
I think you ppl are talking about two different features here, if I'm not wrong.
Dark mode, as a mode for when you are in a dark room and thus activating only 3dof since tracking doesn't work.
Or, dark mode, as a mode where the Quest graphical interface is dark instead of bright.
I would like both ?
dus10lee
Update 8.0 seems to add “Dark Mode” but from the description it isn’t the dark mode I was hoping for.  I just want to watch streaming movies without the lights turned on like I could with my Oculus Go.  My quest doesnt show the update available yet.
