03-02-2021 09:19 PM
My left controller stick keeps on drifting backwards, which makes it harder to move on games like Pavlov and Rec Room. The controller stick also drifts down on the Home Screen. I can’t find out how to recalibrate it. I tried cleaning the control stick with air spray and a q tip with alcohol on it, and it still has the problem. I have also tried disconnecting the controller. The trigger sometimes doesn’t work either, so it mig be a connection issue.
03-03-2021 12:53 AM
Hey there! If you haven't already, try removing the battery for 2 minutes before placing it back in and re-pairing. Make sure that you also check the compartment and terminals for any dust, dirt or debris that might be present as well. Should the issue persist, click here to submit a ticket and we'll be happy to help!
