Oculus link with a low spec laptop
Bloodren
I'm just letting people know after hours of trying to find out and having no success if a lower spec laptop could run the oculus link and it can, just depends on the visuals. I only got to use vader immortal to try out and it seemed fine for the most part. I did experience some crashing while trying to set up the link with the laptop.
If you have this same laptop make sure windows is up to date as well as your drives in your geforce experience, use a usb 3 port with a anker or official oculus cable (I don't have the party link cable)
My laptop specs (acer nitro 5)
Intel i5 8th gen
GPU GTX 1050 4G DDR5
RAM 8GB
I don't know a great deal about computers but I just hope this helps anyone who is in the same position as me with a budget game laptop.
10 REPLIES 10
gmoney0723
Does anyone know whats greater the Ryzen 5 1500X or the Ryzen 5 2500U?
catgamer109
i play on a windows pc, and it works perfectly fine with my vr headset, but will it work with the link cable? my computer has intel i7 integrated graphics
Umpa_PC
Level 8
Whats your VR headset ?
Windows 10 Home Edition Version 10.0.18363 Build 18363, Oculus version 17, Quest Version 17
ohgrant
Level 9
 1500x by a nose https://cpu.userbenchmark.com/Compare/AMD-Ryzen-5-2500U-vs-AMD-Ryzen-5-1500X/m378273vs3921
To the best of my knowledge, WMR standard is the only VR app that will work with intel integrated. Both Oculus and Vive require pretty beefy Nvidia or AMD accelerators.
https://support.oculus.com/248749509016567/
https://www.vive.com/uk/support/vive/category_howto/what-are-the-system-requirements.html
https://www.windowscentral.com/windows-mixed-reality-minimum-pc-requirements
Link compatibility   https://support.oculus.com/444256562873335/?locale=en_US
Gigabyte  AB350 Ryzen 2700x, 32gb ddr 4 3200, 2080ti. HP Reverb G2, Index controllers, Quest 1 and 2x Quest 2. 65" 3DTV HD3D DLP projector.
ericodapro
You can look into getting a video card dock. Its the only way you can connect an external high end video card to a laptop that I know of and Ive been reading that many ppl are having success with it.
vargablood
He will need a Thundebolt 3 interface to use a videodock and iam near sure his acer want own one... They are still rare on most devices ...
ericodapro
Thats only true if you use the TB3 but there are other options out there that use mini PCI-E and EXP GDC. It wont let me post a link or I would. just google it and youll see
vargablood
yes i know those interfaces but thats not really a thing i would recomment for using with a laptop and in customers (vr) gaming situations 🙂
ericodapro
Well those are your only options if your computer is low spec sorry.
