03-01-2021 05:52 AM - edited 03-01-2021 06:25 AM
hello. i am new to the VR community and i know this topic is common but i cant seem to find a solution for my problem 😧
I bought the quest 2 for 1 purpose - Sim racing. Im trying to play it with Oculus Link but for some reason my pc does not detect my vr headset at all despite plugging it into the USB 3.0 / 3.1 port. Ive tried every solutions i can find on the net but none of them works. Ive tried updating my usb ports drivers via device manager (i didnt actually as it says im using the latest version already), reinstalling drivers via device manager, updating my bios to latest version, changing usb ports, reinstalling oculus software, enabling dev and usb debugging, updating both software and vr to the same version (v25/v26). I dont know what else to do.
I am using an aftermarket C to A cable that costed me around $60
However using a REGULAR USB type C phone cable does work but it detects it as USB2.0, not 3.0
Here are my specs:
Zotac RTX 2060
Z390 Aorus Elite
16GB RAM
i5 9400F
03-01-2021 06:20 AM
is your computer a laptop or desktop?
Do you have usb 3.0 ports?
Are the other devices drawing too much power?
03-01-2021 06:25 AM
desktop. i have like 5 usb 3 ports and 3 usb 3.1 ports.
im not too sure. ive only got 2 mouses, keyboard, headphones and g29 (switched off) connected
03-01-2021 07:14 AM
Since the 'regular' cable works, I think it might be the cable. A fair few cables sold seem to be only for charging your devices and don't carry real data or are otherwise limited to USB 2.0.
03-01-2021 07:18 AM
So try removing some items, and putting them in low bandwidth ports.
and if you havent done so test the bandwith of the 3.1 vs. 3.0, if the cable is only 3.0 and its 3.1 slot then it probally wont work to well.
So connect to a blue 3.0 slot and run the test. if you get green dot, then use that port.
Also depending on length of the cable you might stretching a bit with the bandwidth.
Make sure the oculus app software and headset are within 1 version of eachother. If your the beta access channel in the oculus app, just exit out of that.
i would remove the additional mouse, headphones and just use the oculus virtual driver for sound when your sim racing.
03-01-2021 07:19 AM
also make sure any power settings are not set too low. so if your using any power saving features and turn them off, then close out of any capture software that overides your gpu.
03-02-2021 04:56 AM
i am using USBDeview to do the "test". Despite having mostly blue usb 3.0 ports, the software only shows usb 1.10 and 2.0 under the "USB Version"
