Quest 2 hard reset
Tiger_1978
Good afternoon.  My son gifted me a quest 2 and it has all his profile on it.  How to I reset and also, attached the VR to my app on my phone?
kojack
Volunteer Moderator
Volunteer Moderator
There are instructions here: https://support.oculus.com/articles/fix-a-problem/troubleshoot-headsets-and-accessories/troubleshoot...
You'll want the second part "To perform a factory reset using the headset" since you don't have the phone set up yet.
A factory reset will wipe the headset back to "out of the box" state. You can then follow the normal setup to pair with your phone (the headset should guide you). Your son's account won't be hurt, but any data left on the headset will be deleted (like some save games that don't save on the internet).
