Quest 2 link cable PC can't find Quest fix!
joseph_lewis
Honored Guest
I just wanted to post a quick fix in case anyone's an idiot like me. I couldn't use my quest through the link cable for the best part of 6 months because my PC couldn't find the device. I updated drivers, Bios, factory reset, reinstalled Oculus for Windows etc. Etc. Etc.
Turns out that while you have air link enabled, the quest will not connect through the cable. It's there in the menu in small, greyed out writing but it just never occured to me that the two might be might be mutually exclusive. Maybe worth putting in the connecting screen on the windows app?
Might be elsewhere, or might be useless because everyone else is better at problem solving than me, so let me know and I'll remove. Just thought it might be worth a share.
0 REPLIES 0
