Quest 2 with very low audio!
deKaro303
All sound parameters everywhere at maximum volume, but unfortunately the volume is very low, playing with original Link cable and also standalone. With Windows signal improvement a bit louder, but insignificant.
Also inside the Quest 2 everything is set to 100%.
Does someone also have this volume problem with the Quest 2?
My specs:
Win10 pro (64bit)
AMD Ryzen 7 3800X
ASUS ROG STRIX X570-E GAMING
XFX RX 6700 XT QICK 319 (12GB)
G.Skill FlareX 32GB
Latest drivers and Bios.
3 REPLIES 3
byronhinson
Same for me - really low on link and general oculus play
Farah-Eliott
Same problem for me, beat saber sound is OK stand alone, but lone écho is very low, i need add my old headset to understand voice.
Oculus quest 2 64GB
câble link newzerol 5meters/16fts USB C to C, 2.5 gbits/s average mesured, plugged in thunderbolt 4.0 port
Laptop Alienware X17 3080 rtx 150w, I7 11800H, 32bgo ram xmp, 4k screen
deKaro303
The sound volume used to be better at early release, but it crackled. It looks like the reduced it to 75-80% lower to solve that issue. Therefore I think, of course, the volume also suffers. I don't think there is any other solution than that, otherwise Oculus would have implemented it? 🤔
