Quest Guardian advanced settings
Tummie555
So after the update we're able to alter the guardian settings (simple/advanced).  Does anyobody notice any difference between setting the sliders from down low, to sky high? Are the changes suppossed to be effective instantly? Do I need to restart the headset? I tried everything, but I can't seem to notice any difference. Looking for expierences by others...
Tummie555
FYI: Okay, finally figured this one out. The advanced guardian settings don't have any effect on the "stationary circle guardian". In the roomscale it works perfectly.
