Quest - V16 - Experimental Bluetooth Headphones Stuttering
dlamboy
So I have a question:
I initially had a solution where you could
get into the bluetooth pairing via some modifications of the software.
But now as it is nativly supported, I expected at least, that someone
would have fixed the major issue with app stuttering ..  especially
noticable in Beatsaber, while Bluetooth is active.
Will there be any fix soon, or has anyone a solution to this?
I
dont have real cable headphones anymore, and the ones from the
smartphone are not really useful as they pop out on too much movement.
So
it is really a mandatory feature to be able to use bluetooth headset
for games like Beatsaber, or Pistol Whip in my oppinion.
Maybe someone knows better?
0 REPLIES 0
