05-24-2020 01:52 PM
05-24-2020 02:05 PM
05-24-2020 02:08 PM
05-24-2020 02:11 PM
05-24-2020 02:14 PM
pix0c3r0 said:
no in quest store should i buy it
05-24-2020 02:59 PM
05-24-2020 03:54 PM
Umpa_PC said:
If you bought it from the oculus store, via link, you can only play it when you are connected to the computer via link.
For mobile play, you will need to buy it from the quest store (not connected via link).
Beat Saber is not a cross-buy game, so you will need to buy it twice.
05-24-2020 04:39 PM
No. Quest with Link is using the PC, and playing the PC version of the game.
I'm a quest newbie. I thought cross play was paying for it once but being able to play on either a rift or a quest?. If they bought it for the quest i didn't think it mattered if he was using the link cable or not - should be able to play it either way no? Although i guess if he has bought if the quest you wouldn't be using the link cable anyway. (think i just answered my own question)
05-25-2020 03:06 AM
Beat Saber does not support cross play.
For PC you buy a version, for Quest you buy a version.
05-25-2020 06:34 AM
