Quest build v30 Release Notes - Air Link for Quest and more
Oculus_RyanS
These features and enhancements will become available starting the week of June 15, 2021.
Manage Microphone
  • In v30, you’ll be able to swap your microphone between Party and game chat.
  • To switch your mic, go to your Party from the universal menu and select Manage Voice.
Multitasking
  • You can now multitask with multiple system-level 2D apps side-by-side in Oculus Home on Quest 2 and Quest, including Explore, Store, Browser, Events, Oculus TV, Oculus Move, Scoreboards, and more
  • To opt in to this experimental feature, go to the Experimental Features section of Settings and turn on Multitasking.
Color Correction
  • We’re releasing an accessibility feature that lets you adjust how colors are displayed on your device.
  • To begin using Color Filters, go to Settings, select Accessibility, and turn on Color Correction. You can set filters and adjust filter intensity to customize how colors are shown.
Raise View
  • You can now raise and adjust your view, giving you a standing vantage point while physically seated.
  • To opt in to this experimental feature, go to the Experimental Features section of Settings, and turn on Boost your height.
Oculus Air Link for Quest
  • In v28, we announced Oculus Air Link for Quest 2. In v30, we’re now releasing Air Link for the original Quest.
  • You can opt in to this experimental feature from the Experimental Features section of Settings. Follow the instructions on our support site to set up Oculus Air Link.
  • Note: Air Link is part of v30 and it requires both your headset and PC be running v30 software.
Search
  • We’ve made improvements to the search tool and how results are shown.
Casting
  • Performance and connection stability improvements.
Help others find great discussions and answers by adding kudos and marking solutions to your questions.
63 REPLIES 63
Malakai_UK
Just got v30. Now Go Live has vanished from Share. I can’t livestream to Facebook.
Spyder17
I still don't have all the V29 features. Maybe they will show up now.
GoddessLaniakea
where did the go live tab go for livestreaming?
TomCgcmfc
Level 15
I got v30 on my Q1 yesterday.  My Q2 and PC app are both still on v29.  I managed to get Air Link working pretty well with my Q1, even though the release note above say you need v30 on both Quest and PC app.  Lots to new things to explore with v30.  Thanks Oculus.
Anonymous
Not applicable
Official Airlink for Q1 awesome.
I had already tried the the Airlink APK available and it works just great so its good to have it officially in the update.
SiX8SiX
When will you release a fix for tracking randomly shutting off? It’s very annoying can’t play anything at all.
@SiX8SiX  I’m not sure this is a software issue since I’ve never noticed this with my Q1 or Q2, with Link or wireless since v28, v29.  Also fine with v30 with my Q1 (haven’t got it on my Q2 yet).
You are best to work with Oculus support to see if they can help.  Could be a hardware defect that needs replacement under warranty.
I think it a software issue because I have tracking issue on 14 quest 2( there was no problem before the update
AlexiTQ
Level 6
Have you fixed the issues with Link cable yet, or are you still ignoring them - just like support is ignoring my emails?
