Razer Blade Stealth early 2019 connected to Sonnet eGPU 2070
gman713
I bought the Anker 10 meter 3.0 cable that a lot of YouTubers were stating works with the Oculus Link.  When I connect the USB A end into the left USB port, Oculus recognizes it but says there is a problem.  As far as I know, I'm updated to the latest firmware/software my Quest because it has the ability to enable Oculus Link from within the headset but nothing happens, except 3 dots in my Quest.  I also get a notification in the Oculus software that there was a problem.  So am I SOL or is there a way to get it working?  Does the Quest Link not work with eGPUs?  Do I need a laptop with a Nvidia 2070 built in?  Please help
gman713
Does anyone else use an eGPU and has the link working?  I plan on purchasing 5 Oculus games for the rift using the Quest if I can get it working.  I definitely want to support this platform.
gman713
Figured it out!  Works great now!
