Recommendation: >= 10ft magnetic cable from USB A to USB C with fast charging and data transfer
yodli
Hi folks,
Just got a Quest 2. As the title suggests, I'm looking for recommendations for a link cable with the following requirements:
- 10 ft or greater length
- Support fast charging
- Oculus Link support (Data transfer)
- Magnetic ends at USB-C for easy removal
Any pointers online (including AliExpress) are appreciated.
Regards,
T.
Strongit
Level 7
You're going to have a really tough time finding a link cable with a magnetic end.  With the amount of movement you're going to be doing it will lose connection a lot; they're designed to be mostly stationary.  If you're looking for one that just does charging then maybe.  Stay away from AMVR for those, they tend to spark and melt the side of your headset.
As for a regular 10 ft cable both the anker and joto ones work fine for me with my quest 1.
Quest 1, i5-8600K at 4.7 GHz, eVGA 1080 ti FTW3, Gigabyte Z370 AORUS Ultra Gaming, 16 GB 3200 MHz
yodli
thanks, strongit for the feedback. I have ordered the Anker cable. What you say about the movement with magnetic cable makes sense.
