04-19-2021 07:38 AM
When I click on the games ( particularly saints and sinners) I either just see the 3 loading dots or it kicks me out. I tried restarting it like a hundred times and deleted some games to see if it was because of the storage but it is still not working. Does anyone know how to fix it?
06-13-2021 12:33 AM
I am having the same problem with my daughters. Have you figured out how to get the games to work
07-06-2021 09:30 PM
Currently having the same issue... starting to find that there are a lot of issues with the quest that werent there to begin with... like randomly turning off on me (going black) and now this... no idea what is going on, if anyone knows or figure it out?
07-18-2021 07:32 PM
I’m having the same problem. If the game does happen to load it will be the three dots followed by a random frame. Then it crashes. VRchat and pokerstars are unplayable
07-18-2021 07:54 PM
I am.having this issue as well. I have started .asking a list. Some let me in partially and some not at all.
Trouble ticket time.
Good luck to us
07-18-2021 11:18 PM
I have the same issue. I reinstalled the Game and now it's work. But I'm afraid to lose my backup if I do the same for other game.
07-19-2021 12:33 PM
And you shouldn't have to loose game data. None of us should imho
One of the apps not working for me is Prime video. I am going to try the reinstall on that...but I don't want to loose game progress
07-19-2021 12:35 PM
Support jumped right to reboot and if that doesn't work factory reset..
I am pushing back and if we discover another way I will update here.
I have 5 apps not working and more than twice that that are fine. I can't see me doing a factory reboot.
07-19-2021 01:04 PM
I just did a factory reset as recommended and it fixed everything. If you have a pc you can back stuff up so no big deal.
07-20-2021 11:29 AM
Could you explain how make a backup on a PC ?
