Super hot won’t launch
kylejason
Hey peeps. I have a quest 2 and hadn’t played it in a little while. I went to play super hot and it won’t launch. It goes to a screen and says “cloud sync” with a load bar, screen goes black for a second then back to the main menu. Any ideas??
5 REPLIES 5
maddyiscool
I would try uninstalling and reinstalling the app.
FamCow
Same issue, resintalling does not fix problem.
See there is one more post with same issue
https://forums.oculusvr.com/t5/Support/Superhot-vr-for-Quest-2-not-working/m-p/878593#M116400
stickshift20
Same problem here. Sad. Love Superhot.
frozen_wink
Currently having the same issue. Would be nice if we could get a fix, or even a reply regarding the issue...
stickshift20
Figured it out. I had to update the Oculus itself. Go to Settings, About, Software Update. After updating to latest system version, Superhot works again. Yay!
