Using Link cable with Quest 2 still require wifi connection?
IntGami
Hi, I uses the Quest 2 with Link cable connection to run my applications, and when trying to set this up in a new location, the Quest 2 will ask me to pair my device again using a code which means I have to connect to wifi on both the headset and my phone (for the Oculus mobile app). But why is internet access required when we are only running (offline) applications from the laptop? I am using the same laptop and the same headset, so the Oculus desktop app already 'knows' about the headset.
Thanks.
Hey there! Thanks for reaching out today with your concern about why internet is required when running offline. That's an excellent question we'll be happy to answer!
Yes you can use your Meta Quest 2 offline without an internet connection. However, this is assuming you've completed the initial headset setup and pre-downloaded games or movies suitable for offline use.
Are you sure you have a good connection in your new location? Can you move the router as well?
Please let us know!
Hey there! Hope all is well. We're just checking in to see if you still needed our assistance. Please do let us know!
