03-25-2021 08:01 PM
My oculus quest makes a strange concerning popping/crackling sound when plugged in. Should I be concerned and has anybody else experienced this?
Solved! Go to Solution.
07-16-2023 03:24 PM
Hi there @nicooberto0, Thanks for clarifying that it was the headset. We know how pesky this issue can be, considering it can mislead you to know the battery life while playing in VR. We also understand that being able to gauge your battery life visually, can positively affect your play time and not lose progress data by indicating when the headset needs to charge before dying. We would love to do all that we can to assist you on this matter!
Can you please attempt the following troubleshooting to let us know if it helps with the issue:
Please update us on how this goes, can't wait to hear from you soon!
01-19-2022 07:46 AM
i have this issue too but idk how or what is causing it
01-19-2022 04:35 PM
If it's coming from anything other than the speakers, I would definitely keep it unplugged. Audio feedback could be anything, but physical sounds are certainly not good.
01-19-2022 04:52 PM
Hi everyone! This sounds like an issue our team would need to look into 🔎. Please submit a support ticket with the details of your issue, and an agent will happily assist you. 🤗
07-11-2023 03:19 PM - edited 07-11-2023 03:36 PM
Happened to me kinda I was playing beat saber and heard those kind of noises getting louder and louder and the game was lagging and then it turned off not sure what happened it is charging rn making no noises and has the red light so idk Update:I turned it on it is at 6 I haven’t done anything on it yet besides being in the setting up boundary state
07-12-2023 12:26 PM
Hey hey @nicooberto0! I'm a bit unclear on if you're still having this audio issue after charging your headset. It's a good sign that it stopped making the noise when you put it to charge though.
Please let me know if you're still having the audio issue or not, and if you are if it is happening only in Beat Saber or across other apps as well. Looking forward to an update from you!
07-13-2023 04:13 PM - edited 07-13-2023 05:03 PM
Thank you for trying to help I haven’t played since I posted that until know. I beat the level I was struggling on (and crashed on) first try and had no problems. I’m guessing it was a problem with the battery. I played for only a bit and after just played fnaf vr for a bit which was fine too. To be more specific the noise was somewhat quiet at first and I thought it could be a problem with the controllers (they made a buzz when it vibrated but at the time and currently it doesn’t (putting the battery out and back in temporarily fixed it but it seems it’s mostly fixed as I have not heard it in some time.) same problem with the vibration kinda it got louder if I didn’t replace battery, every time it vibrated) but I heard it when my controller weren’t vibrating and it got super loud and then the screen just turned black and now it’s at full battery after charging Update:I played gtag for a bit still fine but I found some list of notifications accidentally and I saw low battery then very low battery bellow that and it said 2d ago also the vibrating thing happened a little it’s not a big problem but still
07-13-2023 05:27 PM
Happy to hear you beat that level; I know some Beat Saber songs can be tricky!
From what I'm understanding, it sounds like the audio issue you had was related to a very low battery. If it comes back or happens again when your headset is fully charged, definitely let me know!
In regards to the vibration with your controller, it sounds like that is related to the low battery too, just with the controller this time. If that becomes more of an issue, let me know that too and we'll look into it further!
07-13-2023 07:43 PM
Good to hear the vibrating thing used to be a bigger issue but the thing says 100% and 90%
07-14-2023 10:24 AM - edited 07-14-2023 10:26 AM
If the vibration ever becomes more of a problem, I would definitely suggest either opening a support ticket yourself, or sending a private message to @MetaQuestSupport to take a closer look.
Until then, I hope you have a good time beating some more levels in Beat Saber and monkeying around in Gorilla Tag!
