Wired connection for quest 2 not working
Duke_Savage
I just got an oculus quest 2 and the air link works fine but when I use a wired connection I get the initial prompt to allow data sharing and I deny but I never get a second prompt to enable the connection.  The cable is good my pc stats are good what is going on!?
Cptbaja
Did you try turning developer mode off as well? The latest update of theirs has broken many core features it seems
Developer mode is off and it is still having the same issue.
