06-27-2022 11:00 PM
Hi. I've been trying to make AirLink work for HOURS only to be told AFTER a full factory reset that my PC isn't compatible. Is there another way to connect my Quest to my PC wirelessly so that I can use the streamer cam in Rec Room?
06-28-2022 12:38 AM
You haven't said what the incompatibility is (and that really matters) but if it's your GPU you could try Virtual Desktop. It's a little more forgiving when it comes to GPUs but if you are trying to run with something like Intel integrated graphics you probably won't get anywhere I'm afraid.
