hi
Lenqbear
hello- can somebody help me? when i try to use oculus air link to play games my quest doesnt connect.
Oculus Community Manager
Hey there. This is not what we like to hear and we want to help get you set up with Air Link to get you back in the game. Before you begin connecting with Oculus Air Link, confirm your Oculus Quest 2 and Oculus PC app are updated to v28 or higher by checking the version in Settings.
- From your PC:
1. Download and update the Oculus PC app .
2. Open the Oculus PC app and select Settings.
3. Select the Beta tab. Select the button next to Air Link.
- Connect from your headset for the first time:
  1. Put on your Quest 2 headset and press [oculus button] to open the universal menu.
  2. Select [gear icon] Settings then select Experimental Features.
  3. Find and select the button next to Air Link.
  4. Read the Air Link Requirements then select Continue.
  5. Find and select your PC in the Available PCs list then select Pair.
  6. Once pairing is complete you can now click Launch.
If these steps did not solve this problem, please submit a ticket and a member of our team will get back to you as quickly as possible.
