light exposure cause headset to stop working
rue-day
My headset was exposed to light and now broken.  need to fix it
PITTCANNA
Level 13
were the lenses(lcd) or were the cameras?
If it were the lenses, those lenses act as magnifying glasses and burn the lcd, theres a warning and cover meant to protect the lenses.  So if you disregard warning and didn't use the cover the fault is on you.
Also its most likely a purchase a new unit if the lcd is burnned.
If the cameras are exposed to light it doesn't matter you may loose tracking hear and there.  But close a few blinds and it will resolve itself.
Umpa_PC
Level 8
In what way is it broken ?
Windows 10 Home Edition Version 10.0.18363 Build 18363, Oculus version 17, Quest Version 17
