10-23-2021 10:52 AM - last edited on 05-28-2023 01:56 PM by AliceinVRworld
My left controller always disconnects if i move it too fast. it makes it hard to play games like gorilla tag or creed rise to glory. no matter how many time i change the batterys the problem keeps happening. any ways to fix it?
Solved! Go to Solution.
10-23-2021 01:25 PM
Hello, NateTheWolf! We understand you're having some issues with your left controller disconnecting. Try cleaning your sensors with a non abrasive cloth and see if that helps!
10-23-2021 01:25 PM
03-26-2022 04:32 PM
We have the same problem. Our left controller connects and disconnects. It’s frustrating! Help please!
03-26-2022 04:35 PM
Hey there! We know how confusing it can be when these issues occur and we want to be able to help. We would like to recommend you try to unpair and repair your controllers to your device, as well as taking the batteries out for 30 minutes and then reinserting them. If does not help, please feel free to submit a ticket with our support team so we can look into this for you. You can visit our support site using the following link. https://metaque.st/Support
04-16-2022 12:02 PM
I traded three headsets for the same reason. I recently read a solution, it did it to me again but the solution worked. My left controller stopped connecting completely. I grab a pair of tweasers and inserted them into the same slot that you pulled the plastic from when you originally bought it. Apparently where the tabs once where something shifts and the battery can't power the controller. Signs that it's about to happen are when u notice that the controller vibrates just because you are moving it. This helped me, I hope it can help you and anyone reading this.
04-16-2022 12:15 PM
Wow, answers from support are extremely unlikely to help. Cleaning your sensors? really? Good luck with that.
Try a different set of batteries-- for size, not for charge. Use a different brand of battery. If your connection issues are due to batteries losing physical contact, batteries that fit a bit tighter (just due to slightly different size) may help.
04-24-2022 07:26 AM
@NateTheWolf I'm having the same problem. I also see a solution was accepted. Did the problem get fixed?
07-22-2022 04:06 PM
My left control won't even connect anymore is there away to refurbish my left hand control
07-23-2022 01:56 PM
Hey there. We know what it is like to be really into a game, only to deal with the controllers not connecting anymore. Let's look into this, and see what we can do to get you back into gaming!
What troubleshooting steps have you already tried? When did you notice this not working?
Can you please try the following:
If none of these work please reach out to Support HERE and we can further assist you.
09-06-2022 01:11 PM
it didntt
