oculus link cable not working
gdubbb21
I have the oculus link cable it was working fine up until a week ago, it does not connect at all, ive tried everything in restarting, disabling enabling drivers, reinstalling oculus , it does not give power anymore, the usb C on my motherboard works fine, just the cable is not working.
Hey gdubbb21,
While we can assist in troubleshoot many things involving the Oculus, the Link Cable is one of those where we need extra information we won't be able to collect here.
If you could please collect the logs from the computer you've been using and send them to us in a support ticket
Here are the instructions on how to collect the logs.
    • The above link is the default directory. Bear in mind that if you installed Oculus Home to another drive you will need to update the command with the correct file path.
  7. Attach the newly created zip file to your support response.
We look forward to helping you get back into VR.
