oculus link won't start
Sped_fr0m_space
My oculus link has stopped working recently, I can't use the oculus link feature even though everything is working fine like it shows that my quest is connected on my computer and all that but when I try to start oculus link my screen goes black and I see the loading dots for about a minute and then it stops and I go back to the home screen and on my computer it tells me that it cant find my headset even though its still connected fine.
1 ACCEPTED SOLUTION
Accepted Solutions
Sped_fr0m_space
Turns out I just had to update a driver or something lol
4 REPLIES 4
Oculus Community Manager
Hey there! Sorry to hear you are having issues with the Link, could you open a support ticket with us here and include the log files from your system. Thanks!
texdade
If you are playing on a laptop, try setting it to your Nvidia GPU, for some reason oculus link doesn't like the integrated GPU anymore
Sped_fr0m_space
what do you mean set it to my nvidia gpu because i have a laptop
