quest 2 not appearing on pc
i've been trying to transfer files to my headset for about 2 hours now
i've updated my drivers, restarted both headset and pc and tried every port on my pc but the pc refuses to read the quest 2 as being a connected device.
The headset works fine from Air link, bluetooth synchs up as well but does nothing but says it's connected, but hard wiring into my pc it's like it isn't even there. Side request, can we just have wireless file sharing or transfer already? Really clunky to need to hardwire in and go through a full process like this
MurphlesZA
Hi, I had a similar problem when I discovered that when Air Link is enabled in the Oculus, the wired connection won't work. Try turning off Air Link in your Oculus and then connecting to your computer again.
