09-23-2021 12:19 PM
Hi all
i have an oculus quest on the latest firmware with the official oculus link usb c to c cable and it seems im stuck in usb 2 speeds for some reason.
i have the usb tree info for anyone who can help
=========================== USB Port5 =========================== Connection Status : 0x01 (Device is connected) Port Chain : 2-5 Properties : 0x0D IsUserConnectable : yes PortIsDebugCapable : no PortHasMultiCompanions : yes PortConnectorIsTypeC : yes ConnectionIndex : 0x05 (Port 5) CompanionIndex : 0 CompanionHubSymLnk : USB#ROOT_HUB30#4&2b5667ed&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} CompanionPortNumber : 0x15 (Port 21) -> CompanionPortChain : 2-21 CompanionIndex : 1 CompanionHubSymLnk : USB#ROOT_HUB30#4&2b5667ed&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} CompanionPortNumber : 0x16 (Port 22) -> CompanionPortChain : 2-22 ========================== Summary ========================= Vendor ID : 0x2833 (Oculus VR LLC) Product ID : 0x0186 USB Version : 2.00 Port maximum Speed : High-Speed (Companion Ports 2-21 and 2-22 support SuperSpeed) Device maximum Speed : High-Speed Device Connection Speed : High-Speed Self powered : yes Demanded Current : 0 mA Used Endpoints : 5 ======================== USB Device ======================== +++++++++++++++++ Device Information ++++++++++++++++++ Device Description : USB Composite Device Device Path : \\?\USB#VID_2833&PID_0186#1PASH9A9YX0226#{a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE) Kernel Name : \Device\USBPDO-6 Device ID : USB\VID_2833&PID_0186\1PASH9A9YX0226 Hardware IDs : USB\VID_2833&PID_0186&REV_0404 USB\VID_2833&PID_0186 Driver KeyName : {36fc9e60-c465-11cf-8056-444553540000}\0007 (GUID_DEVCLASS_USB) Driver : \SystemRoot\System32\drivers\usbccgp.sys (Version: 10.0.19041.488 Date: 2020-11-19) Driver Inf : C:\Windows\inf\usb.inf Legacy BusType : PNPBus Class : USB Class GUID : {36fc9e60-c465-11cf-8056-444553540000} (GUID_DEVCLASS_USB) Service : usbccgp Enumerator : USB Location Info : Port_#0005.Hub_#0002 Location IDs : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(5), ACPI(_SB_)#ACPI(PC00)#ACPI(XHCI)#ACPI(RHUB)#ACPI(HS05) Container ID : {dadba582-1e39-5ea9-a7f3-e7e954212db3} Manufacturer Info : (Standard USB Host Controller) Capabilities : 0x94 (Removable, UniqueID, SurpriseRemovalOK) Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER) Problem Code : 0 Address : 5 HcDisableSelectiveSuspend: 0 EnableSelectiveSuspend : 0 SelectiveSuspendEnabled : 0 EnhancedPowerMgmtEnabled : 0 IdleInWorkingState : 0 WakeFromSleepState : 0 Power State : D0 (supported: D0, D3, wake from D0) Child Device 1 : Oculus Composite XRSP Interface Device Path 1 : \\?\USB#VID_2833&PID_0186&MI_00#6&14a0f774&1&0000#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} (ANDROID_USB_CLASS_ID) Device Path 2 : \\?\USB#VID_2833&PID_0186&MI_00#6&14a0f774&1&0000#{dee824ef-729b-4a0e-9c14-b7117d33a817} (GUID_DEVINTERFACE_WINUSB) Kernel Name : \Device\000000a7 Device ID : USB\VID_2833&PID_0186&MI_00\6&14A0F774&1&0000 Class : AndroidUsbDeviceClass Driver KeyName : {3f966bd9-fa04-4ec5-991c-d326973b5128}\0000 Service : WinUSB Location : 0000.0014.0000.005.000.000.000.000.000 LocationPaths : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(5)#USBMI(0) PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(5)#USB(5) ACPI(_SB_)#ACPI(PC00)#ACPI(XHCI)#ACPI(RHUB)#ACPI(HS05)#USBMI(0) ACPI(_SB_)#ACPI(PC00)#ACPI(XHCI)#ACPI(RHUB)#ACPI(HS05)#USB(5) Child Device 2 : Oculus Composite ADB Interface Device Path 1 : \\?\USB#VID_2833&PID_0186&MI_01#6&14a0f774&1&0001#{dee824ef-729b-4a0e-9c14-b7117d33a817} (GUID_DEVINTERFACE_WINUSB) Device Path 2 : \\?\USB#VID_2833&PID_0186&MI_01#6&14a0f774&1&0001#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} (ANDROID_USB_CLASS_ID) Kernel Name : \Device\000000a8 Device ID : USB\VID_2833&PID_0186&MI_01\6&14A0F774&1&0001 Class : AndroidUsbDeviceClass Driver KeyName : {3f966bd9-fa04-4ec5-991c-d326973b5128}\0001 Service : WinUSB Location : 0000.0014.0000.005.000.000.000.000.000 LocationPaths : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(5)#USBMI(1) ACPI(_SB_)#ACPI(PC00)#ACPI(XHCI)#ACPI(RHUB)#ACPI(HS05)#USBMI(1)
Thanks
11-25-2021 08:27 PM
I have the same issue. Have you got any solution ?
=========================== USB Port6 =========================== Connection Status : 0x01 (Device is connected) Port Chain : 1-6 Properties : 0x09 IsUserConnectable : yes PortIsDebugCapable : no PortHasMultiCompanions : no PortConnectorIsTypeC : yes ConnectionIndex : 0x06 (Port 6) CompanionIndex : 0 CompanionHubSymLnk : USB#ROOT_HUB30#5&7082e34&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} CompanionPortNumber : 0x02 (Port 2) -> CompanionPortChain : 1-2 ========================== Summary ========================= Vendor ID : 0x2833 (Oculus VR LLC) Product ID : 0x0137 USB Version : 2.10 Port maximum Speed : High-Speed (Companion Port 1-2 supports SuperSpeed) Device maximum Speed : SuperSpeed Device Connection Speed : High-Speed Self powered : yes Demanded Current : 0 mA Used Endpoints : 3
11-25-2021 08:57 PM
01-18-2022 03:09 PM
c'est un problème récurent chez oculus, ils ne savent pas résoudre ce problème, j'ai tout essayé, j'ai fait tout ce qu'il m'ont demandé de faire, et pourtant ca ne fonctionne pas, j'aime pas dire ça mais ils sont incompétent.
ils vous font tourner en rond en vous demandant de faire énormément de manipulation jusqu'à ce que vous craquiez. adieu oculus, vive vive!!
