v28 Missing Experimental Features
Starnova42
My Quest 2 is on v28 but I don’t have 120hz or tracked desk, and I’ve tried everything I’ve seen in forums, restart headset lots of times, reset experimental features, and change languages. The farthest I’ve gotten was downloading the sideload zip file for v28, which got me the Airlink and tracked keyboard. Any new suggestions?
1 ACCEPTED SOLUTION
Accepted Solutions
When I reset experimental features, virtual desk showed up, so I guess the features are also slowly rolling out
3 REPLIES 3
TomCgcmfc
Level 16
It took me almost 2 days after getting v28 on my Q2 to get all the experimental options.  I did get Air Link after a reset of experimental though.  Maybe your problem is because you side loaded v28.  I don’t know but it may be stopping you getting the full update?  If I were you I’d consider doing a factory reset.  This may take you to the proper v28.  Good luck mate.
Ya, but if you have not got the rest like 120Hz and desk in a 2-3 of days I would then consider a factory reset.  Hope you get these without needing to do this.  Let us know.  Cheers,
