v28 air link and 120hz
SecondSword1738
Air link was officially released today and i have updated my quest 2 to v28 and my Oculus app on my pc to v28 but i still do not have any v28 features on my quest. I have the air link option on my pc but not on my quest. Is there any fix for this? I have already restarted my quest several times and reset the experimental features tab many times as well.
5 REPLIES 5
captainjirk
same thing here!
PinkRoadCone
Same here
heynewt
same here
chert1024VR
Try resetting to default the Experimental features. After the Quest 2 reboots those features should now appear.
If the 120hz appears but not the Air Link, that means you have to wait for another V28 version update. My Quest 2 actually had two V.28 updates  and after that both 120hz and Air Link appeared.
heynewt
Thanks.  I reset the Experimental Features twice, still not there.  Then I shut down fully for a couple of minutes and rebooted.  Finally it showed up.
